Run high flow fuel pump on tbi and pressure regulator?
Old Apr 20, 2012 | 01:30 AM
camarorokr's Avatar
Car: 1991 Camaro RS
Axle/Gears: GM 10 Bolt 3.42
I just diagnosed my car to have a bad fuel pump so I came to wonder if it's possible to use a high performance fuel pump (something equivalent to an LS1 pump - planning on LS1 swap in near future) with the stock TBI system? I know it would be too much pressure from common sense, so would a fuel pressure regulator allow my car to run with that much of a pump? I'm just trying to eliminate doing this fuel pump swap again and I haven't even got started on my first try lol. I'm not sure if this is a stupid question but feel free to make me feel stupid if I sound stupid!
Old Apr 20, 2012 | 06:33 AM
ex-x-fire's Avatar
Re: Run high flow fuel pump on tbi and pressure regulator?
A higher flowing pump will work ok as long as the regulator & return line don't become the restriction in the system. I have a tpi pump on my tbi 350, I can set my pressure at any point between 9-18psi, above that the regulator bottoms out & the pressure spikes to over 40psi. A walbro 255 seems like a good start.
Old Apr 20, 2012 | 10:27 AM
Ronny's Avatar
I would think a Delco brand TPI pump is high quality. Has Delco quality changed?
Old Apr 20, 2012 | 11:28 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
I use the AC Delco Vortech pump, same rating as the LS pump in OE stock form. Its a little noisier than the TPI pump but the output is better.
http://www.ebay.com/itm/NEW-AC-DELCO...item231c4d7707
That's the pump in our 89 TBI car. It runs great!
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
