350 tbi swap in a rs questions
Old Apr 29, 2012 | 06:17 PM
zcotter19's Avatar
Im looking at a 91 rs and the guy said it has a 350 tbi engine from a truck in it. i was just wondering about some specs on this type of engine in a 3rd gen. what would the aproxamate gas milage and hp/torque be. also is it a reliable engine, is this something that people often put in rs's because there stock engine isn't the best i know that.
Old Apr 29, 2012 | 06:18 PM
zcotter19's Avatar
Re: 350 tbi swap in a rs questions
Also its a 5 speed just as another bit of info
Old Apr 29, 2012 | 06:19 PM
one92rs's Avatar
Car: SOLD!!!!!
look above your post in the stickies. that will give you a lot of info on this and what should have been done. truck will most likely be the l05 engine.
Old Apr 29, 2012 | 09:01 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
L05 I think had around 210 HP stock if I am not mistaken. Up until the middle of last year. I was getting 23 MPG wit 350 tbi w/some performance mods a 700r4 with 3.42 gears.
Old May 5, 2012 | 11:34 PM
RicerEater78's Avatar
Mines not an l05 like yours more than likely is, but its an 87 tpi 350 that was installed with the tbi that I had to change some parts on. Swapped injectors, iac, and tps. Runs fine, idles just a bit rougher than stock because I'm running the stock chip, but I was getting about 26-27 MPG on the highway. not sure about the HP numbers. I'd guess between 200 and 210 at the crank though.
Old May 6, 2012 | 12:47 AM
zcotter19's Avatar
thanks for the input
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
