Engine code 10243880/TBI?
Old May 5, 2012 | 09:32 PM
tj186kmps's Avatar
I have found a never used 5.7 crate engine with this code. I am not sure if it is ZZ4, but I think the heads are iron. This motor is still in the crate. I have a 1995 TBI 350 Chevy truck. Will this motor work with my intake/TBI injection? It is a single rear seal motor. What HP should I expect. Thanks
Old May 6, 2012 | 06:39 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Re: Engine code 10243880/TBI?
That block was used for a lot of different crate engines. From ZZ4's to stock replacement vortecs engines. I would run the numbers on the heads to get a better idea of what it is.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
