when replacing the stock pump
Old May 15, 2012 | 10:15 PM
car.ramrod's Avatar
when replacing the stock tbi pump with an ep241, do you have to readjust the fuel pressure? ~13 pound regulator should stay there should it not? also there is an insulation sleeve that came with my install kit, how many of you have left that sleeve off? seems to me it's used to keep noise down but i was figuring that if it was left off the pump may run cooler.
Old May 16, 2012 | 10:02 AM
SCCAjunkie's Avatar
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
Re: when replacing the stock pump
In theory, it *should* stay, but I wouldn't count on it. I'd be ready with a gauge and such to adjust it.
I would not leave the sleeve off. The pumps are cooled internally by the fuel flowing through them, and the heat that would bleed off through the outside surface would be marginal.
Old May 16, 2012 | 11:15 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
run the sleeve. and the regulator determines pressure not the pump. the pump delivers fuel volume.
Grant2k
Jul 10, 2018 04:01 PM
NBrehm
Aug 25, 2015 11:49 PM
justin57
Aug 20, 2015 07:05 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
marcusaw
Aug 10, 2015 08:13 AM
