Still having stall issues
Old Jun 2, 2012 | 12:38 PM
Bulslayer85's Avatar
Car: 89 Camaro RS
Engine: 305 v8
Transmission: Automatic(modified)
Ok so i replaced the fuel filter and i know the pumps good cause its getting plenty of fuel. The idle sits steady around the 5 mark but i got a friend that says it should be more around the 10 mark and car starts to stall if i get on the accelerator to fast. What should i ask the mechanic to look for when i take to shop on monday?
Old Jun 2, 2012 | 05:19 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Still having stall issues
Tried doing this yet? You should
https://www.thirdgen.org/tpimod2
Old Jun 10, 2012 | 08:36 PM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
i had a problem a few years back where my camaro would stumble and die if i did not stay in the gas at a red light, it would get violent, bucking and everything
Check every related part you can think of to an idle issue, mine ended up being a bad ecm
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
Bryan F
Aug 18, 2015 02:28 PM
