high rpm cutout
Old Jun 19, 2012 | 09:40 PM
dairy's Avatar
Car: 90 Camaro
Engine: 305 TBI
Transmission: 5 speed
Axle/Gears: 3.42 POSI
high rpm cutout
So I was running my stock tbi with a 14in k&N, xstream top, and a drop base. It ran great. Tonight I removed the tbi spacer and used a flat base. I think it ran better at low rpm but there were two flaws. It ran hotter and when running down the road at high rpm ( near govenor) it would sputter and have little power. Why would this simple change make it run worse and not better.
Old Jun 20, 2012 | 11:17 AM
Ronny's Avatar
Re: high rpm cutout
Vac leak ? Does it idle same RPM?
Old Jun 20, 2012 | 07:24 PM
dairy's Avatar
Car: 90 Camaro
Engine: 305 TBI
Re: high rpm cutout
I dont think its a vac leak, it idles the same and it ran normal when i switched back. I think the issue was the air coming in from the side of the injector rather than coming in from top to bottom of the injector.
Old Jun 21, 2012 | 02:20 AM
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
Re: high rpm cutout
Thats the main reason of going to a flat base is to allow more airflow. my guess would be its leaning out at higher rpm's, its now not getting enough fuel for the amount of air coming in. If you aren't already running an adjustable fuel pressure regulator, get one. my car stock was at 11.5 psi and i now have it at i believe 13 or 13.5 psi. This should fix your high rpm lack of power with the flat base.
Old Jun 21, 2012 | 12:13 PM
dairy's Avatar
Car: 90 Camaro
Engine: 305 TBI
Re: high rpm cutout
Sounds like a good thought and wouldnt be a bad idea. What regulator would you recomend?
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Stryker412
Sep 7, 2015 09:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
