83 TA Pace Car CFI fuel pump issue
Old Nov 15, 2012 | 02:38 PM
gooseman73's Avatar
Hey everyone, my father in law has an issue he cannot figure out. He has a 83 TA with CFI and its 100 percent stock. It quit running and he tried several different FP relays but nothing will change the voltage at the pump, which is a steady 8V. Anyone have any ideas? Thanks!
Old Nov 15, 2012 | 02:46 PM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
Re: 83 TA Pace Car CFI fuel pump issue
What is the voltage at the battery?
Old Nov 15, 2012 | 02:47 PM
gooseman73's Avatar
a full 12 volts
Old Nov 16, 2012 | 08:35 PM
Damon's Avatar
Is the pump bad? It's just an electric motor, after all. If it's got a short in the windings it's going to draw more juice (lower voltage at the pump) and pump less fuel.
Old Nov 19, 2012 | 09:06 AM
gooseman73's Avatar
I understand that, but it has 8 volts on the feed lead when its not connected to the pump.
Old Nov 19, 2012 | 09:11 AM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Well if the battery has 12 volts and it drops to 8 at the pump connector that would seem to indicate that there is a problem with wires / relays / whatever in between the two. I would get out the multimeter and wiring diagram and start doing tests along the path to the fuel pump.
Old Nov 19, 2012 | 09:21 AM
gooseman73's Avatar
I can do that but just wanted to make sure this wasn't a common GM issue like so much of the stuff is.
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
djmarch
Aug 9, 2015 05:27 PM
Kaweh
Aug 9, 2015 02:54 PM
