92 gmc tbi fast idle column switch
Old Dec 24, 2012 | 08:34 AM
racin69z's Avatar
My 92 gmc with a tbi 350 has a high idle problem. I have looked all over the web and cant find anyone with similar simptoms. It has an intermittent problem where it idles high in gear. It doesn't do it in park. The other day I found that if its idling in park just fine and I grab the shifter and move it almost all the way to reverse but not in reverse, it will idle high. I am trying to figure out what role the column switch plays in all this.*
Lynn
Old Dec 25, 2012 | 08:06 AM
ex-x-fire's Avatar
Re: 92 gmc tbi fast idle column switch
I'd check the neutral safety switch, the ecm monitors it to see if its in park,drive, ect. See if its adjustable, maybe its loose.
Old Dec 25, 2012 | 06:30 PM
racin69z's Avatar
I think the switch is working as intended. Its just idling wayyy to high while in gear. I was just holding it almost in gear to verify it was an input from the switch causing it to idle high. I don't know why it intermittently feels the need to idle high in gear
Lynn
Old Dec 26, 2012 | 02:30 PM
Ronny's Avatar
Clean the IAC. May or may not help...
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
