TBI conversion. no start
Old Jan 1, 2013 | 02:12 AM
davesengineshop's Avatar
Car: 1983 Z-28
Engine: 454
Transmission: TH700R4
Axle/Gears: 7.5" with 3.23 gears
I have kind of an interesting issue with my Camaro.I recently put a 454 in it and then decided to put the TBI system from the donor truck in it. The problem I am having is it will not start without adding fuel down the throttle body. after it starts it runs ok.I am pretty sure that the injectors don't fire while cranking. Now according to the wiring diagram that I have the I the "injector A" fuse is only powered with key on. Could it be that the "injector" fuse is suppose to be hot while in run and start? Or is there some other possibility.
Old Jan 1, 2013 | 09:10 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TBI conversion. no start
Yes, hot in both run & crank. You likely wired it to an accessory feed, which is cold during cranking.
RBob.
Old Jan 1, 2013 | 09:13 AM
Car: 1983 Z-28
Engine: 454
Thanks. i shall fix that after I drink coffee.
Edit: Fixed! Starts right up and runs good. now route the wiring and secure it. then get it ready for racing
Old Jan 7, 2013 | 01:02 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Racing a TBI?
By all means elaborate.
92camaroJoe
Jul 29, 2023 07:57 PM
pimp2303
Jul 27, 2017 02:03 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
