Fuel & return lines
Old Jan 4, 2013 | 11:14 PM
A-Z camaro guy's Avatar
Car: 82 z28
Engine: 350 carb
Transmission: 350
Axle/Gears: 10 bolt 3.42
Fuel & return lines
I know this is a little off topic concerning f body's but I'm using lots of parts from a 92. I'm doing a v8 swap in an s10 & didn't label the fuel lines when I removed the engine from either vehicle. To make it worse I was planing to go carbed & removed the fuel tank & lines. Can someone give me an idea of the correct plumbing?
Old Jan 5, 2013 | 10:13 AM
ex-x-fire's Avatar
Re: Fuel & return lines
Use an open end wrench to figure out the line diameter, 3/8 is the main feed line, 5/16 is the return, & then there is the vent line, 1/4 diameter.
Grant2k
Jul 10, 2018 04:01 PM
AkDrifted
Aug 17, 2015 07:45 PM
wayshegoes
Aug 17, 2015 12:00 PM
armybyrd
Aug 10, 2015 09:23 PM
Kaweh
Aug 9, 2015 02:54 PM
