Lo3 install 454 tbi system
Old Feb 5, 2013 | 06:18 PM
Brichards79's Avatar
Car: 1989 camaro rs
Engine: lo5
Axle/Gears: 373 with detroit limited slip
Hello I've been having trouble with my stock tbi unit play I'm the throttle shaft and sticking I'm going to get a 454 tbi unit I have replaced air cleaner assy with a 14inch round edlebrock and advanced timming to 6 after market cat back system. I'm going to get software and programmer to tune at the same time I get bigger tbi unit question is will I be able to tune enough to get running right before I do headers cam heads and intake
Old Feb 5, 2013 | 08:33 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: Lo3 install 454 tbi system
ok had to read that twice. a 454 tbi on a stock engine will not net you anything. you need to replace or modify your stock intake to run that. and the stock tbi will run the stock engine just fine with some tuning. you don't need the 454 tbi on a stock engine. look up FAST355 and read his posts and go to his pages and learn.
Old Feb 5, 2013 | 08:37 PM
Car: 1989 camaro rs
Engine: lo5
I know it will not gain anything now. But I need a new tbi unit. I'm going to modify engine soon so I was thinking go a head and get the bigger tbi unit now instead of having to buy twice
Old Feb 5, 2013 | 08:39 PM
one92rs's Avatar
Car: SOLD!!!!!
ok that makes sense. as long as you know it will drip fuel a tiny bit due to the bores being larger in the tbi than on the intake. there will be a ridge there.
Old Feb 5, 2013 | 08:53 PM
Car: 1989 camaro rs
Engine: lo5
I could bore stock intake or change intake do u know what intake will fit larger tbi unit
Old Feb 5, 2013 | 09:45 PM
Chad85T/A's Avatar
Car: 85 T/A
Get a dual plane carb intake for your TBI heads and a TBI adaptor plate.
Old Feb 6, 2013 | 12:59 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I used a Performer RPM intake with a Transdapt adapter plate and it worked great. A bigger throttle body on a stockish engine is a waste of time. a stock unit is good for 330hp with the Ultimate mods. You can bore your stock intake to 50mm no problem and port out the runners ALOT. I have a stock TBI intake that I ported for a client to a 1205 gasket and still had a TON of meat left in the ports. I'll see if I can post pics of it later.
MustangBeater20
Oct 29, 2022 09:20 PM
Fast355
Dec 2, 2016 06:33 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
