Terrible fuel consumption!!! (please help)
Old Feb 7, 2013 | 04:21 AM
greekknight's Avatar
Last September I bought my car. This is the first Trans am I ever owned.
I knew about the bad fuel consumption these cars have but in my case for sure there is a big problem...All this time I didn't had the chance to drive my car because I had to do some repairs. One week ago I started to use it for some weekend cruising and I realized that my fuel consumption is 5 MPG in the city!!!!!
My car has a cracked filler neck and I loose some fuel but only whenI fill it up.
I have replace: air filters, fuel filter, transmision filter and oil,oxygen sensor,TPS sensor, engine oil and filter, spark plugs, fuel pump...
My car is a 1982 Trans am with the 305 V8 crossfire engine and it has 92.000 original miles (engine is bone stock).
Old Feb 7, 2013 | 07:03 AM
ex-x-fire's Avatar
Re: Terrible fuel consumption!!! (please help)
Make sure that map sensor is hooked to the right port, no vaccum leaks.
Check your coolant temp sensor, early ones were troublesome. Get a newer style sensor & pig tail.
Fuel evaporates, so that big leak is causing some of your fuel to go into the air. I've seen cars like that, the tank will become bone dry if you let it sit. Plus its very dangerous, get that fixed.
Old Feb 7, 2013 | 07:46 AM
Thank for your reply!
Is it possible to have a map or a coolant sensor problem without a check engine code?
Someone told me to check also the injector/jets. What is your opinion?
Old Feb 8, 2013 | 02:38 AM
This morning the car went to the mechanic to fix the filler neck problem.
Old Feb 17, 2013 | 10:00 PM
Chachi361's Avatar
Car: 1992 Camaro rs
Engine: Stock 305
Transmission: 5 speed
i had the same problem but my car ran almost perfect so i knew it was someting other than the actual motor. it turned out to be that my o-ring to the fuel sending unit was worn and wasnt sealing properly changed that and i get to use every onnce of gas i put in the tank. haha
Old Feb 19, 2013 | 02:50 AM
You mean the o-ring of the fuel pump?
Old Feb 19, 2013 | 06:23 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Have you checked the ignition timing? Are any of the brakes sticking? How is the general driving experience? Are there any problems during acceleration or is it very sluggish? Does it need higher RPM than it should just to cruise around?
Old Feb 19, 2013 | 07:07 AM
ignition timing o.k
brakes o.k
Driving experience good, acceleration good
RPM's normal
Old Feb 19, 2013 | 08:12 AM
fernando1's Avatar
Engine: 5.7tbi
5mpg this is something abnormal, if your fuel does not leak anywhere and if car drive well check your engine oil for gasoline smell, it could be that gas is going down to oil. I know it can happen rare, but could be one of the reason. Also check you exhaust for gasoline presence.
Maybe you could first change you gas station, and fill up your tank fully to check properly your MPG.
Old Mar 5, 2013 | 01:53 AM
Thank you for your help, It turn out that I had the same problem with you!
Old Mar 5, 2013 | 01:56 AM
Chachi361's Avatar
Car: 1992 Camaro rs
Engine: Stock 305
Glad I could help
Old Mar 5, 2013 | 02:52 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
What the...
How did you find THAT out?
It's not as if you could simply LOOK at that unit. did you remove the entire tank for that?
Old Mar 5, 2013 | 05:50 AM
ex-x-fire's Avatar
Have some shop smoke test it.
Old Mar 5, 2013 | 08:49 AM
Chachi361's Avatar
Car: 1992 Camaro rs
Engine: Stock 305
I have a little door that the previous owner made above the fuel sending unit. Thank god because I would of hated to drop the rearend and tank and that not be the problem. I knew the problem was something to do with the tank because I would fill up in the summer and by the next two days I would lose about 5 gallons of gas with the car just sitting there
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
