IAC raising idle/neutral rpms
Old Feb 15, 2013 | 05:11 PM
Banks4004's Avatar
Car: 1990 Camaro
Engine: 5.0
Transmission: T5 WC
Recently my car has been acting up by constantly raising the rpms to about 2500 every time I push in the clutch. And sometimes its like the throttle was stuck and my car would drive itself when I didnt have my foot on the pedal. I cleaned the TB, replaced the IAC, and made sure the throttle cable was not sticking. I'm not sure why the IAC is being told to bring up the rpms but it was so annoying I just unplugged it and dont use it at all. I'm not throwing any codes either. Does anyone know what might cause this?
Matt
Old Feb 15, 2013 | 05:33 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: IAC raising idle/neutral rpms
check for vacuum leaks especially the tbi base gasket. have you checked the throttle body for wear in the throttle shaft it may be causing the plates to bind.
Old Feb 23, 2013 | 06:32 PM
Banks4004's Avatar
Car: 1990 Camaro
Engine: 5.0
Transmission: T5 WC
I finally got time to change the base gasket (actually 2 of them the PO installed a spacer with a flow passage in it) and I think it fixed my problem. It does not drive itself in gear anymore. It does still raise the rpms when I push the clutch but not as high and doesn't come down to idle as fast as when I unplugged the IAC. Is this normal behavior?
pacoelrapido
Sep 11, 2015 02:41 PM
IROCtometal
Sep 9, 2015 10:01 AM
Jk_Under
Sep 8, 2015 08:13 AM
greenyone
Sep 2, 2015 03:39 PM
