Swapped intake causing shift points to be off
Old Mar 5, 2013 | 07:47 AM
tlman12's Avatar
So I recently swapped out my intake on my 91 rs with tbi with an aftermarket edelbrock. The intake was slightly higher then the stock intake so I believe that it messed with the tv cable. I messed with it a little bit trying to adjust it back to where I thought it should be but I think I successfully made it worse because now it slams into drive and the shift between 1st and 2nd is really hard and waits till 3k rpm no matter how hard I'm accelerating.
I want to try to understand exactly what it's doing when I lengthen or shorten it before I go messing with it. Can anyone explain it to me? Never had to deal with one before.
Old Mar 5, 2013 | 11:49 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Swapped intake causing shift points to be off
Changes the line pressure. To adjust it push in the D tab and pull the cable housing toward the firewall. Now fully open the throttle at and by the lever arm on the TBI unit (NOT by the go-pedal).
The TV cable is now adjusted.
RBob.
Old Mar 5, 2013 | 07:07 PM
goliath88's Avatar
Car: 88 firebird convertible
Engine: 305 tbi v8
RBob.
This Man is my Hero.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
86White_T/A305
Aug 17, 2015 12:16 AM
gwade12
Aug 8, 2015 08:17 AM
