vacuum line on 89 camaro tbi question?
Old Mar 21, 2013 | 11:09 AM
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
Okay so there is a vacuum problem on my moms 89, im trying to figure it out.
Where the canister(front of car driver side), theres a line that goes right to the left of it, idk what that part is called, but when i press it in the RPM goes up(just like im pulling the throttle, it also moves when i press the black rubbery part)
My question is, from the canister there is a vacuum line that goes to a conecter for 2 more lines, one line goint to what i believe is the press control valve. But where does the other line go???
I'm sorry if i don't make sence, if needed i'll take a pic when i get back home. Thanks.
Old Mar 21, 2013 | 12:00 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: vacuum line on 89 camaro tbi question?
Old Mar 21, 2013 | 04:22 PM
Beef's Avatar
Car: 89 RS
Engine: Stock L03
Transmission: Stock T5
Axle/Gears: Stock, Too high
The diagram is missing the cruise control vac motor, and the reservoir. The vac res is a ball down under the canister, seen easily from underneath. The C/C motor is a small can/valve looking thing in the left front by the core support, probably what you're playing with that's varying rpm, since it in fact acts on the throttle.
Old Mar 22, 2013 | 11:34 AM
Jk_Under's Avatar
Engine: 305 5.0L
Size:  24.8 KBName:  IMAG0045.jpg
Size:  24.7 KBName:  IMAG0046.jpg
Old Mar 22, 2013 | 11:35 AM
Jk_Under's Avatar
Engine: 305 5.0L
see how the three lines connect up? and one isnt going anywhere.
Btw whats that part im touching in the second pic?
Old Mar 22, 2013 | 12:30 PM
Beef's Avatar
Car: 89 RS
Engine: Stock L03
Yeah that's your cruise control vac motor/actuator/whatever, the one that's not hooked to anything is probably supposed to be hooked to the vacuum reservoir, goes down thru the fender, there should be a large black plastic ball under the panel the evap canister is sitting on, you can see it from beneath the car, that is the reservoir and it should have a vacuum line hooked to it. The line is commonly pulled off and then forgotten since the reservoir is out of sight and the line usually ends up just dangling in the fender.
Old Mar 22, 2013 | 02:07 PM
Jk_Under's Avatar
Engine: 305 5.0L
ok i know exactly what you're talking about, thanks alot! And thanks for that diagram tuned, it showed another hose misplaced, appreciate it.
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
apie2546
Aug 10, 2015 05:43 PM
