Tbi running rich and smoking
Hi guys, I need some ideas on what to do next. I have a stock 96 vortec engine with a 92 tbi on top. Brian at TBI chips burned a custom chip for me and it has run great for more that a year. My problem is it is running so rich it fouls plugs and blows dark grey smoke. Gas is getting in the oil. I have a new
GM heated o2 and a new cts. The timing is spot on with the tan wire unpluged. I watched the o2 last night on winaldl and it was at .960v before it went to closed loop. Then it jumped between .860v-.960v and around zero. Im running Brians fpr spring at 17psi. Im thinking about throwing in the other spring I have to get to 15psi and replacing the map sensor. The injectors are not dripping. I'm going to datalog and video it tonight. I will post the video tommorrow.
I need some ideas!
Thank you,
Eric
I need some ideas!
Thank you,
Eric
Re: Tbi running rich and smoking
Did the engine EVER run "right"?
Proper vacuum supply to MAP sensor???
What is scan tool data for coolant temp, and short- and long-term fuel correction?
Is the ign. timing advancing when you rev it? That'll cause a low vacuum reading.
You need to check the fuel pressure, maybe a restriction in the return line is causing high pressure.
Check the ecm grounds.
Yes the timing advances when i rev it. I put a vaccum gage in line with the map sensor and it read 18" at idle. Put new coil in last night before i data logged. I 'm posting several pictures and data. See what you guys think.
20130319_195121_LOG.txt
20130319_200153_KNOCK.txt
20130319_201244_BLM.txt
More data, The plugs are black again, even got a cough of flames through the tbi. There is some of water coming out tailpipe, but no bubbles in radiator. when you hit the throttle you cant see anything and the fuel smell will make your eyes water.
If it was running good and now it's not it's most likely a mechanical issue. Any recent work done on the truck? Is firing on all cylinders? If it's missing it can cause a rich condition. Injector leaking maybe? You can hook a timing light up and point it at the injectors while it's running to check the spray pattern. Start with the basics I bet this will be something simple.
Injectors look good. I put a different spring in the regulator to get the fuel pressure down. I got it down to 13 psi and it still smoked. It would barley run. I had to unhook the map just to get it to idle. After it warmed up i saw bubbles in the radiator. Little confused because the smoke is grey and im fouling some plugs. Looks like headgasket. I'm going to rent the tester from the parts store tonight and make sure i burp the radiator good.
Car: 89 Camaro Iroc Z
Transmission: MK6 World Class T5
Axle/Gears: 9 bolt had 3.45's, now 3.27 gears
I had a tbi stage 2 chip tune until it washed my cylinder walls of oil and wore my rings so bad that my engine would smoke 24/7. His tune ran great but it gave me the exact symptoms you have and destroyed my old engine in a year. Your better off burning your own chip.
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Run a compression check before jumping to this conclusion...
92camaroJoe
08-13-2015 06:07 AM
