LO3 + LT1 = which injectors?
Old Apr 13, 2013 | 09:33 PM
gearheadotaku's Avatar
Car: '91 Firebird
Engine: 305 TBI w/LT1 cam
Transmission: T5 swapped in
Axle/Gears: 9 bolt 3.27 w/discs
Planning a LT1 cam swap for my LO3. Should I add the 350 injectors or will the 305's keep up? Using the stock heads and the slightly larger 350 ex. manifolds and y pipe, 3.23 gears and 5-speed. Not trying to make huge power, 200hp at the crank is plenty provided I don't lose torque.
Would I be better off with a B-body cam over a Camaro cam?
Old Apr 15, 2013 | 06:44 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: LO3 + LT1 = which injectors?
don't have to get bigger injectors you can increase the PSI of your injectors. upgrade to headers forget about manifolds. Headers anda full exhaust will give you more gain than the cam will.
New2Chevy
Sep 28, 2015 12:35 AM
webeeZ28
Sep 14, 2015 12:00 PM
64Chief
Sep 12, 2015 08:05 AM
Stroopwafel
Sep 11, 2015 06:38 AM
L0tuS
Sep 4, 2015 11:16 PM
