Code 43
Old May 1, 2013 | 02:35 PM
djdsails's Avatar
Car: 92 camaro RS
Engine: Moded 350 engine
Transmission: 5 speed
Code 43
So this is different. I am driving and datalogging with winaldl. I noticed code 43 was thrown, electronic spark control. But I got no dash warning light. No rough running, no real noticable signs of something wrong. Just a flag on the computer. I recently did a swap, 305-350. Also new esc module for the 350. I just checked that the wires going to the starter and knock sensor were far away from spark plug wires.
Any thoughts on whats going on?
I have been doing some reading and I have seen so far are ppl having this code in conjunction with poor performance and unreliable engine.
Old May 1, 2013 | 03:04 PM
djdsails's Avatar
Car: 92 camaro RS
Re: Code 43
i unplug the ESC and the dash light come on, the flag on the computer stays on
Old May 1, 2013 | 05:04 PM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
Re: Code 43
When my GTA/350 was running rough, it threw, MAF, EGR, TPS, and ESC at me. I replaced all 4 and the car runs good now. In hind site I probably could have tried to just do EGR and TPS to see if the others were real or just side effects ???
Damn thing is tho, ESCs are like $80.
I'd clear it and see if it returns.
Old May 1, 2013 | 08:50 PM
djdsails's Avatar
Car: 92 camaro RS
Re: Code 43
the knock sensor is new and the ESC is new with the engine swap. this flag wasnt coming up a wk ago, it was all of a sudden today i flipped through the tabs in winaldl and it was checked off. the car runs great, like nothing is wrong. i can feel a slight difference b/w this wk and last wk vibration wise, its just slight though. i am assuming the ignition module went, thats the last piece of the system. i plugged in my old knock and grounded it and my old ESC ( they came off of my old running 305 that came out) and started the car and the flag was still checked.
Old May 1, 2013 | 09:10 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Code 43
Idk but a 305 uses a different knock sensor than a 350 does. Why did u ground the knock sensor? You can't bypass it by grounding it
Old May 2, 2013 | 05:45 AM
djdsails's Avatar
Car: 92 camaro RS
Re: Code 43
I plugged the old 305 knock into the harness just to see if anything changed
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
