83 z28 crossfire/tbi
Old May 11, 2013 | 10:41 PM
loujon's Avatar
engine has slight surge after timing. idles at 650-700 rpm then surges t about 1000rpm then back to normal. what's the problem?
Old May 11, 2013 | 11:12 PM
kauboy's Avatar
Car: 83 Z28 Crossfire
Re: 83 z28 crossfire/tbi
Surging after you reset the timing?
Old May 20, 2013 | 11:34 PM
loujon's Avatar
yes. engine idles around 750 - 800 rpm cold but surges to 1000 rpm at warm/hot idle. up and down between 750 - 1000 rpm.
Old May 21, 2013 | 01:06 PM
Ronny's Avatar
surges are typically vac leaks. Odd it appears after timing verification...
Old May 25, 2013 | 03:56 PM
kauboy's Avatar
Did you disconnect the EST when you set the timing?
Old Jun 10, 2013 | 06:40 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
any updates?
Old Jun 11, 2013 | 01:03 AM
david_351's Avatar
Could be a dribbling injector, sometimes as the injectors age they will dribble a little fuel at low speeds (idle), and as the engine picks up the excess fuel it surges. As mentioned it could also be an air leak somewhere, take a propane torch and gomaround the upper and lower intake seam, base of the lower manifold etc, if the engine revs up anywhere you know what gasket needs to be replaced.
You can try dialing up the fuel pressure a bit, this sometimes can be a bandaid fix for dribbling injectors. Check the PCV valve too
starliner
Feb 9, 2016 08:18 PM
blackz281le
Jan 11, 2016 07:51 AM
David Frans
Oct 31, 2015 08:12 PM
Night rider327
Oct 9, 2015 09:25 AM
z28joe2
Sep 28, 2015 05:54 PM
