Well first I would like to say that I am a new member to the Third Gen family. I recently (well for a couple months now) have had a '89 Camaro RS 305 TBI. And I absolutely love it. Ive already had quite a few memorable moments and I know ill have more. But unfortunately, im having an overheating issue. So, what ive done so far.
-Changed faulty thermostat (tested multiple times and ways and it wasnt working)
- Swapped to a new radiator (at first I didnt notice any cracks in the old one but after driving it one day I soon saw where the crack was)
-Rigged the fan in front of the radiator to run 24/7 (it wasnt running period, no matter how hot the car got)
And so, it still over heats. Im a bit of a novice when it comes to this. I am still learning the ropes. But if anyone has anything that I might overlook or should check I would greatly appreciate it.
Do you have the air dam and what temp is it running and are you having to put a lot of fluid in it?
Quote:
To be honest I am not exactly sure what the air dam looks like. But it climbs past the red zone and yes I have noticed I do put alot of fluid in. And add some little by little as the temp rises.Originally Posted by jdawg1276
Do you have the air dam and what temp is it running and are you having to put a lot of fluid in it? Member
It's the black plastic thing that hangs low in the front of the car the scraps ever bump you hit
Quote:
Ill go check, I think i certainly hear it.Originally Posted by jdawg1276
It's the black plastic thing that hangs low in the front of the car the scraps ever bump you hit Quote:
Yup, I see it.Originally Posted by jdawg1276
It's the black plastic thing that hangs low in the front of the car the scraps ever bump you hit Member
Get some on to pressure test it may have a leak at intake manifoild. Or could be bad water pump o and when I bought my 88 it overheated leaked to come to find out it was radiator cap it wouldn't hold pressure
Quote:
Hmm, well I am not sure if itll mean anything. But I watched the water circulate in the radiator and when the temp rose I saw the exchange and the cool fluid come in and change the color. Is it possible my water pump is still bad? And is it possible to pressure test it myself? Or is it one of those things that require expensive equipment lol. And i re-used my radiator cap from my old one to new one. Bad idea? Seemed like it fit snugly.Originally Posted by jdawg1276
Get some on to pressure test it may have a leak at intake manifoild. Or could be bad water pump o and when I bought my 88 it overheated leaked to come to find out it was radiator cap it wouldn't hold pressure Quote:
thanks! now i need to know whats the pressure to look forOriginally Posted by ex-x-fire
you can rent a pressure tester at autozone/adv auto. Member
About the water pump not shore I know I had one that worked fine but once you shut it off it would leak as for the radiator cap it is the spring that is important take it off and see if it's really loose and ask around to your friends to see if they have a pressure tester doesn't take long to do
Just make shore you have money to fix the problem because I had intake gasket leaking a little but after test it leaked really bad couldn't drive it into till I fixed it
Some one can chime in but you just pump pressure into the system if there is a leak u will see it spraying out but that's all I know
Quote:
Thanks, the next thing I was going to replace was the water pump. I got error codes 43 and 15 from my computer and im not sure if theyve got anything to do with my problem. But ill look into pressure testing.Originally Posted by jdawg1276
About the water pump not shore I know I had one that worked fine but once you shut it off it would leak as for the radiator cap it is the spring that is important take it off and see if it's really loose and ask around to your friends to see if they have a pressure tester doesn't take long to do Member
I would pressure test before buying water pump may be something cheap first imo
Quote:
Interesting I woke up his morning. Cranked up the car. The temp seemed to stabilize around 220. I saw smoke/steam coming from the radiator cap. Then next thing I knew there was some pressure leak shooting from the top left area of my engine compartment. I should have probably looked exactly where but I panicked closed the hood and quickly shut the car off. I see my the valve train cover to the left is wet and the tube going to the block were the thermostat sits was a little wet.Originally Posted by jdawg1276
I would pressure test before buying water pump may be something cheap first imo Ok, so I think I found the culprit. Or atleast where to start. I attached a pic of where smoke is coming from. I believe between my 6th and 8th cylinder?
Is it a bad coolant temperature switch or do u have aftermarket gauges?
Quote:
Sorry I didnt ask when I bought it and im not sure.Originally Posted by jdawg1276
Is it a bad coolant temperature switch or do u have aftermarket gauges? Member
Quote:
If you don't have any extra gauges in the car, chances are its stock. And if it "EJECTED FLUID" then chances are the water pump is functioning. Correct me if I'm wrong? Could have just been pressure...Originally Posted by Chris787n
Sorry I didnt ask when I bought it and im not sure. Between Cyl6 & 8 on the passenger side sits a sensor that turns the fans on at roughly 220* and turns it off at roughly 200* (per the gauge, and per the manual). If the sensor is even a little loose, it will kick out coolant when the system pressurizes (at heat).
TO KNOW IF THE SENSOR IS FAULTY: Let the car run idle. If the radiator fan NEVER turns on (circa 220* per the gauge) then the sensor is bad. If the fan turns on, move on to step 2...
STEP TWO: Since you're already going to have to get under the car to tighten the sensor, I would HIGHLY recommend replacing it with one from Hypertech that turns the fan on at 200* and off at 180*. They make a 180*on/ 160*off sensor but I feel as though that's to cold for the oil, and then you don't get heat!
You wont NEED to put any kind of leak tape (that white stuff) or tread sealer on it, I mean you can, but its a B**** to tighten... but it works.
STEP THREE: While you're at it, and the coolant is out (when you remove that sensor you WILL be baptized by coolant) throw in a 180* thermostat. It opens wide at 200* and starts to close at 180*, you know, so it works really well with the fan sensor setup.
All in all with that setup, the car will run much cooler. Personally, I swapped my radiator to a thicker tricore aluminum one (There's an article on here somewhere...) but thats quiet expensive if you don't need to.
All in all when I did all of the about (with radiator) in the CA heat of 100+ degree's outside, my engine ran at 190-210* at a stand still. With the AC on I was at roughly 220-235, but hey... thats still "stock" standards. But thanks to CA heat I feel like a cooling expert!
Quote:
Correct me if I'm wrong, but this picture almost looks like the 2ndCly? Are those the battery cables near the front? 6 & 8 are more... cluttered. Uh... check that stupid T looking thing that the coolant lines run into that sits unsupported on the top of the engine... its plastic... it leaks... its stupid. Originally Posted by Chris787n
Quote:
That looks like the drivers side in the picture #5 & #7 cylinder? The birdcage of grass below is a giveaway---always collects on the drivers side by the firewall..
