Help! Valve stem seal fixed?
Old Aug 19, 2013 | 10:11 PM
inchaos10's Avatar
Car: 1989 Camaro RS
Engine: 305 tbi
Well this is my first post. I have a 89 Camaro rs with 305 tbi. The car was running perfect with the exception of some smoking. So I took it apon myself to change the valve stem seals and o-rings. After completing the job without taking the heads out using the string technique.
Put it all back together and now I have a rough idle. After multiple valve adjustments I have gotten the car to idle pretty good and respond decent to pressing the gas pedal. But when I turn my ac on now it bogs down almost to where it sounds like its going to die and response is slow and sluggish like its missing. I swear to myself its a vacuum leak. But WHERE!! Everything thing seems fine.
Im going to get some starter fluid tomorrow to see if I can find any leaks.
Is there something I am missing that I should have done? Any help would be much appreciated.
Old Aug 21, 2013 | 04:54 PM
Schurkey's Avatar
Re: Help! Valve stem seal fixed?
First question: Did you install the O-ring seals BEFORE or AFTER you installed the spring retainer?
The common failure is to put the o-ring in the valve groove, then install the retainer and keepers. This is not correct. The retainer must be installed, then the O-ring put on the valve stem, then the keepers.
HOW are you adjusting the valves? I'd expect that--barring a vacuum leak or broken valve spring or other reassembly mistake--the valve adjustment is too tight, so some valves aren't properly closing.
gixxer92
Sep 1, 2015 04:32 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
86White_T/A305
Aug 17, 2015 12:16 AM
