heater hose goes here???
Old Sep 11, 2013 | 08:35 PM
mreld3r's Avatar
Car: 1986 Iroc, 89RS
Engine: 350 tpi, 350 tbi
Transmission: 700r4,700r4
Axle/Gears: 4.10,2.73
89 rS tbi 350.
The PO removed the a/c and heater from my car before I got it.
I am re-installing everything.
I'm not sure if the intake came from a truck or camaro tbi.
There is NO where to put the heater hose.
I know one hose goes to the radiator.
But; there is no nipple on the front of the intake, ONLY on the rear of the intake...next to the distributor. Is that really where it goes?
Or,,,should I remove the rear nipple and put it on the water pump.
Never had a TBI before; so I really don't know where to put the other hose.
I looked at tons of tbi pictures; but there is so much stuff on them I cant see the heater hose.
thank you tbi-guys
mike
Old Sep 12, 2013 | 06:50 AM
ex-x-fire's Avatar
Re: heater hose goes here???
Yeah, use the rear nipple, there's a coolant channel the runs under the tbi mount, it helps heat it up in cold weather. That's why the nipple location is different then the traditional intakes.
Anything behind the water pump is pressurized, so you couldn't hook up to the heater core from the top of the water pump or radiator, it won't heat or flow well.. One has to come from the intake.
Old Sep 12, 2013 | 07:03 AM
mreld3r's Avatar
Thank you SO much, I would not have "ever" guessed that it went back there.
I just thought that something weird was going on back there.
Also; the intake gasket has "restrictor plates" in the back water passage, I would have left them out...I guess that they are correct also.
thank you
Old Sep 25, 2013 | 04:23 PM
topj's Avatar
Car: 88 Camaro IROCZ Convertible
Engine: 305 tbi
Transmission: auto
this is my issue right now too. no heat no ac, and the one hose to the nipple on the rear. What type of hose do i need to connect to the heater core inlet? and is there anything else i need in order to get the heat working again?
heres how my bay is looking
Attached Thumbnails heater hose goes here???-photo11_zps3d61f1a0.jpg   heater hose goes here???-photo21_zps18919e15.jpg   heater hose goes here???-photo31_zps206c59e8.jpg
Old Sep 30, 2013 | 07:58 PM
topj's Avatar
Engine: 305 tbi
Transmission: auto
im guessing any 2 hose split? or do i gotta run one hose one way and one the other comming out the heater core?
Old Oct 25, 2013 | 03:51 PM
topj's Avatar
Engine: 305 tbi
Transmission: auto
im a amature so bare with me lol
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
