LO3 High Idle
Old Sep 13, 2013 | 07:50 AM
92ArticRS's Avatar
Car: 1992 Camaro RS Heritage
Engine: 305 TBI
Transmission: BW 5spd
LO3 High Idle
Hey guys, I am new to the forum and I need a little help. I have a 92 RS with a 305 TBI and it was suffering from a crazy rich at idle problem. I checked the injectors and they seem to be firing okay. So, last night I installed an injector reconditioning kit along with a new IAC and Air Charge Temp Sensor as well. After re-installing the TBI unit, I went for a test drive. That seemed to have fixed the rich problem but now I have a high idle problem. It only occurs after I have been cruising and I take the car out of gear to come to a stop. The RPMs go to +/- 2500 then settle down to 1500. I have to leave the car sitting for a minute or more before the RPMs settle down to 750 again. Any thoughts?
Old Sep 18, 2013 | 04:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
I'm moving this to the TBI forum with the expectation that you're more likely to get a useable answer than you would on the Tech/General Engine forum.
Old Sep 26, 2013 | 12:07 PM
Brichards79's Avatar
Car: 1989 camaro rs
Engine: lo5
Axle/Gears: 373 with detroit limited slip
Re: LO3 High Idle
i would check for a vacum leakor maybe sounds like the throttle plate is sticking i had the same problem adjust the idle screw untill i just hits the plate and turn it a half turn more
Old Sep 30, 2013 | 06:25 PM
92ArticRS's Avatar
Engine: 305 TBI
Re: LO3 High Idle
How did you overcome the sticking throttle plate?
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
