tbi ecm question
Old Sep 21, 2013 | 12:57 PM
mreld3r's Avatar
Car: 1986 Iroc, 89RS
Engine: 350 tpi, 350 tbi
Transmission: 700r4,700r4
Axle/Gears: 4.10,2.73
tbi ecm question
'89 rs with a 350 tbi swap.
1228746 ecm with correct chip.
When I try to datalog; the cts reads -40C.
I have checked out the cts and wire to the ecm with a meter.
I can read the cts @ the ecm connector with a meter.
I have a good ground @ the cts sensor connector.
The ECM "refuses" to see the cts sensor?
Anyone ever have this problem?
I am setting a code 15 (coolant temp sensor -27 degrees after engine has been running for more than 30 seconds),,not surprised here,,,it reads -40C "always"
thank you
mike
Old Sep 22, 2013 | 06:40 AM
mreld3r's Avatar
Re: tbi ecm question
Never mind; I was a little "hasty" on my diagnosis.
I cut the wire @ the ecm and put a 300 ohm resister on the yellow wire.
The other end of the resister went to ground.
Warmed up the car and it ran perfect,,no trouble codes and the datalog read 170 degrees. So; I have a wiring problem from the ECM to the cts.
Now to completely expose the harness and find the bad spot.
The only thing I can think I did wrong; was, maybe,,, when I thought I was reading the cts @ the ecm connector,,,I was reading the resistance through my fingers and instead of 300 ohms or so; I was actually reading 30M ohms or so, and I didn't see the decimal point on the DMM?? It has happened before.
It's amazing how a nights sleep can change a problem.
mike
Old Sep 22, 2013 | 09:40 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The reading of -40 is from an open circuit. It could be the sensor is open or the wire is open, or the engine block ground for the sensor is open.
At 72*F the resistance of the sensor is around 3200 ohms.
RBob.
MustangBeater20
Oct 29, 2022 09:20 PM
Jae992
Aug 27, 2015 09:07 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
