Backfiring...Due to being too lean?
Old Oct 1, 2013 | 12:58 AM
my3rd's Avatar
Car: 1991 firebird XS
Engine: 5.7 tbi
Transmission: stock 700r4
Axle/Gears: 9 bolt 3.23
okay,i know this is going to sound dumb...okay so now that you are prepared here it is, a while back i built a mild 350, installed it in my 91 bird in place of the LO3. i used the stock manifolds, AIR, y-pipe and cat...today i installed headman shorties, y-pipe and no cat. now the car pops and gets a pretty consistant backfire which stalls it. so thinking it was a timing issue due to more flow and not being tuned (ordering my ebl this week RBOB) needless to say, my attempts at adjusting the timing didnt help for more than 5 min. i am using a 350 tbi with the ultimate tbi mod done, the ecu...well we will just say thats the stupid part, its the original LO3...im just shocked that the car changed sooo drastically with just a header setup. is there anyway you can think to fix this until i get an EBL and learn what it does? im 9.5 comp, xe 268 cam if that matters at all? thx
Old Oct 2, 2013 | 03:12 PM
Brichards79's Avatar
Car: 1989 camaro rs
Engine: lo5
Axle/Gears: 373 with detroit limited slip
Re: Backfiring...Due to being too lean?
hey i had a simlar problem with my car i unhooked the ecu timming wire single brown wire going to ecm mine is on passenger side near ac box and back fire stoped ran like **** put that told me the ignition controll module on the distributor or pick up coil was bad so i replaced the whole unit and runs great ever since
F-body-fan
Jan 12, 2023 01:49 PM
db057
Jan 10, 2020 08:55 PM
Elephantismo
Feb 13, 2019 12:51 AM
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
