83 crossfire injection fitting
Old Oct 6, 2013 | 09:32 PM
Mechanized's Avatar
I am helping a co-workers kid get his camaro running. I walked into the project late. The fitting for the fuel inlet is what size? Where can I source one? I imagine it has a shoulder as I found a plastic washer on the intake manifold.
Secondly would it be worth it to swap to carb? If so what parts would I need to swap for other than intake, carb, linkage?
Old Oct 7, 2013 | 06:24 AM
ex-x-fire's Avatar
Re: 83 crossfire injection fitting
I think the fitting sizes are that same one you find on sae brake/fuel that they carry at parts stores. The main is 3/8 & return is 5/16.
For the swap you'll need a vacuum advance distributor & a fuel pressure regulator (to get the psi down to around 5 psi).
Old Oct 11, 2013 | 06:40 PM
kauboy's Avatar
Car: 83 Z28 Crossfire
[quote=Mechanized;5647712]I am helping a co-workers kid get his camaro running. I walked into the project late. The fitting for the fuel inlet is what size? Where can I source one? I imagine it has a shoulder as I found a plastic washer on the intake manifold.
If you're talking about the fitting that screws into the throttle body, it should be 12mm x 1.25. Depends on which one you're missing I might have an extra one lying around.
toronto formula
Nov 10, 2015 06:17 AM
z28addict8490
Sep 5, 2015 03:56 PM
3tas4me
Sep 4, 2015 01:45 PM
3rdgenparts
Aug 6, 2015 09:03 AM
