89 camaro rs wont idle
Old Oct 19, 2013 | 10:02 PM
nissinator's Avatar
please help I have an 1989 Camaro rs 305 tbi. it will start but barely run and will die. I replace the EGR value, the IAC value and the PCV and hose going to the throttle body. my map sensor tested to be good. after doing all that it runs a little better but not much, instead of just dying it tries to keep it self running it has very low idle and will still stall most of the time.
Old Oct 25, 2013 | 11:04 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
Re: 89 camaro rs wont idle
test fuel pressure
Old Oct 26, 2013 | 03:53 PM
Schurkey's Avatar
Originally Posted by Caveman305
test fuel pressure
Good advice.
I'd also inspect the distributor cap and rotor, plug wires, and spark plugs. It would be worthwhile to do a cranking compression test, a leakdown test, and a cylinder-balance test; all to determine basic engine condition.
After that...it's scan-tool time.
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
db057
Aug 22, 2015 08:17 PM
