Fuel injector holder 305 tbi
Old Nov 17, 2013 | 06:31 PM
91camarox's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Hi guys so today when I was replacing my regulator I over tightened a bolt and broke the bottom half that holds my injectors I can't seem to find the holder at a part store and the one camaro I found that had it at a junkyard it was stripped so I'm curious if I'm naming it wrong or searching wrong and also what other vehicles carry a 305 tbi that I could swap with
Old Nov 17, 2013 | 06:37 PM
Re: Fuel injector holder 305 tbi
That's not a carb thing, so this is the wrong forum...
But, aside from that, TBI is TBI is TBI is TBI, where most of those parts are concerned. (obviously there are exceptions, the injectors themselves for example, but, I'm sure you get the idea) They couldn't care less what sheet metal they're wrapped in or what bore & stroke they're mounted above. Clever that way, those engineers. So go back to the boneyard and find a 2-bbl TBI off of practically ANYTHING - truck, Caprice, 305, 6-cyl, 454, WHATEVER - odds are, the piece you need will be the same. Take yours with you and match em up to be sure.
Old Nov 17, 2013 | 06:46 PM
91camarox's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Is thre anyway to move it
Old Nov 19, 2013 | 03:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Moved it to the TBI forum for you.
Old Nov 19, 2013 | 08:49 PM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
listen to what sofakingdom suggested, the entire TBI unit on my camaro right now is off of an early 90's truck, the injector pod is the same across the board(454 may be different/bigger, not sure), just use your injectors in it
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
kyleb24
Aug 15, 2015 08:24 AM
