350 Motor HELP
Old Jan 5, 2014 | 11:22 PM
Xephy's Avatar
Car: 1992 Camaro RS
Transmission: A4
350 Motor HELP
I found a 350 block with the casting number of #10064727
Will this drop in a 92 camaro which is 305 tbi stock?
Old Jan 5, 2014 | 11:26 PM
Xephy's Avatar
Car: 1992 Camaro RS
Transmission: A4
Re: 350 Motor HELP
Also, another block casting #3970010
let me know what will work! thanks
Old Jan 6, 2014 | 04:50 PM
Schurkey's Avatar
Re: 350 Motor HELP
Either BLOCK will drop right in.
You'll need a different flywheel/flexplate if you use a two-piece rear main seal block. You may need a different damper and matching timing cover.
Cylinder heads are a different matter.
Someone other than me will have to help you with the tuning/fuel delivery problems of installing a 350 in an application that is set up for a 305.
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Out-Cast
Aug 17, 2015 10:57 AM
st.evel07
Aug 13, 2015 06:15 PM
