idle fuel spray question
Old Jan 30, 2014 | 09:56 PM
nelsonwes24's Avatar
Car: 1991 camaro rs
Engine: 305 v8
Transmission: auto
hey yall have a 91 305 tbi auto question since this is my first tbi car ive owned , as i previous had a 86 camaro v6. so with the car in park and running on top of the throttle body is only 1 injector suppose to be spraying out fuel or both cause i only see my driver side one putting out alot and the other not. thanks
Old Jan 31, 2014 | 01:45 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: idle fuel spray question
They spray pattern is the same on bolth injectors assuming thy are in good condition. You can use a timing light hooked up and pointed at the injectors to see the pattern better or drips.
Old Jan 31, 2014 | 02:48 AM
Schurkey's Avatar
Does the engine idle smoothly?
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
redmaroz
Aug 16, 2015 11:40 PM
92camaroJoe
Aug 13, 2015 06:07 AM
killer777
Aug 8, 2015 02:47 PM
