350-L98-Vortec head swap EFI question
Old Feb 5, 2014 | 04:31 PM
Chuck84TA's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Swapping out my L69 for a 350 build in my 1984 Recaro.
I was originally thinking of keeping the qjet but after some thought I am examining the options for fuel injection.
I understand that swapping over to EFI is probably going to run close to $3000 but if it gives me a smoother running engine, power in the 320hp range and keep the stock "look" with the functional hood scoop air cleaner, I may consider it...
So, my questions are as follows
1- will my stock air cleaner with the functional hood scoop still work with a TBI system?
2- what good options are there for this kind of setup?
Thanks!
Chuck
Old Feb 6, 2014 | 10:23 AM
Ronny's Avatar
Re: 350-L98-Vortec head swap EFI question
Depends on the height of the intake. Holley and Edel publishes that info on their TBI intakes.
Many. If you want FI I would strongly suggest port fuel. Intake height would apply.
I was able to purchase aluminum spacers with integral 0 rings at .50 inch for the air cleaner spacing from Jegs. I bet they could easily be machined.
Old Feb 12, 2014 | 01:37 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
you have so many kits now, MPFI, All these ez efi systems if you're in a situation where you don't need a stock appearing vehicle those are great options.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
