84 Z28 carb 305 switch to TPI 350?
Hey everyone I have an 84 Z28 stock 305, I have an aggressive shift kit installed in the 700R4 tranny, now I bought a 350 block that is cracked but it has a ton of aftermarket on it, including the fact that it is tune port injected, I just don't know what I need to switch it over. There's a ton of information on here and I don't know what to sift through. The motor I bought has holly fuel injectors, an over-sized crane camshaft, edelbrock headers, a rebuilt alternator pushing 80amps with a chrome pulley, the waterpump has an aluminum pulley on it. Now on my car I already pulled the smog pump and AC pump off of it and all it's components so what will I need exactly to swap this motor? Any help or guidance is appreciated.
Car: 1983 Z28
Engine: 385 Fastburn
Re: 84 Z28 carb 305 switch to TPI 350?
My advice would be to buy a not-cracked 350 block, swap your parts over, and drop it in.
I have a 4 bolt main 350 block not cracked, just trying to figure out what would be the best approach before i stick it in the car, it's easier to do everything now while it's on the motor stand. What do I need to do to switch it over from carb. to TPI?
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
