new to the group with vacuum issues.
Old Apr 20, 2014 | 07:38 PM
biggins87's Avatar
Car: 1987, chevy r 10
Engine: vortec headed 350, with mild cam
Transmission: built 700r4
Axle/Gears: 3.73 rear
I have an 87 Chevy r10 that I bought about 10 years ago and have slowly been rebuilding. As the truck sits its a stock bottom end, vortec headed 350, with a Holley 670 cfm tbi, long tube headers, and I deleted the air pump in the reinstalation. Buy now once the truck gets alittle heat built in the block it won't stay running do to a vacuum line issue but I seem to be having a problem finding out what I need to change veins I deleted the air pump, do I need to change something or will I have to buy a chip for it to accept that there isn't a air pump anymore? Any advise would be greatly appreciated, thanks in advance.
Old Apr 21, 2014 | 11:17 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: new to the group with vacuum issues.
Holley TBI's are known for issues. Make sure that your MAP sensor is on the manifold vacuum fitting. If I recall correctly the Holley TBI uses a different port for the MAP sensor than the stock GM. Other than that you will need a a correctly tuned chip for the vortec setup.
Old Apr 22, 2014 | 06:39 AM
biggins87's Avatar
Ok thanks for the advice, what would be a better choice for an aftermarket tbi for that truck? Also who would be a good tuner in the Kansas city area for the tbi?
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
HoosierinWA
Oct 7, 2015 10:15 AM
bjpotter
Oct 4, 2015 07:48 PM
dusterbd
Sep 29, 2015 08:40 AM
