xfire fpr mod
Old May 6, 2014 | 05:24 PM
xfire's Avatar
xfire fpr mod
Hi all. I am wanting to raise my fuel pressure. so do i need to mod both tb's or just the rear. Is it just as easy as in the tech article listed here, or do the xfire units require different steps. Thanks in advance
Old May 7, 2014 | 03:56 PM
Ronny's Avatar
Re: xfire fpr mod
One of the two I beleve is not a FPR but an actuator(spell?). Its purpose is to smooth out the flow or something similar. So you leave that one alone. Or run the TB's parallel and replumb. In that case remove actuator and block off with a plate.
Fuel pressure shouold be 11-13 lbs. None higher.
Old May 8, 2014 | 01:49 PM
xfire's Avatar
Re: xfire fpr mod
done easy peasy. my pressure did not go up so i pulled the tank to swap pumps and found the rubber hose turned to goo. new hose and all is well.
I didnt think it would ever idle.
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
Lmancha96
Sep 25, 2015 08:11 PM
Strick1
Sep 4, 2015 07:11 AM
