AE vs PE
Old May 20, 2014 | 05:47 AM
usc iroc's Avatar
Car: 89 Iroc
Engine: 383
Transmission: 700
Axle/Gears: 4.11
AE vs PE
Could someone enlighten me on these 2 settings? Differences etc....
Old May 20, 2014 | 09:18 AM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
Re: AE vs PE
AE is used to add fuel at the moment the throttle is pressed. For example, you are cruising and maintaining a constant speed and then suddenly push down harder on the gas. This is just a very short burst of fuel kind of like a pump shot in a carb.
PE is used to add fuel and keep the motor at some constant AFR (typically something like 12.5:1). Usually if you are in PE mode, the throttle is fully open or very close to it. In PE mode the motor runs in open loop, so there are no adjustments being made based on O2.
Old May 21, 2014 | 05:32 AM
usc iroc's Avatar
Car: 89 Iroc
Engine: 383
Transmission: 700
Axle/Gears: 4.11
Re: AE vs PE
Thank you Pound....
