got the combination set up. now need the cam
Car: SOLD!!!!!
1. 355 flat top pistons with valve reliefs
2. summit racing 162108 heads. 62 cc 2.02i 1.60 ex 170cc-in 69cc ex
3. edelbrock 3704 intake gasket matched and bores ported
4. cfm tech ported tbi 620 cfm.
5. hooker shorties and ypipe. high flow cat and magnaflow catback
6. 3.23 posi diff
7. built tranny with 1750 converter--stock.
ROLLER CAMS please. was looking at this one. but I want all opinions. idle to 5500 is my rpm range.
Camshaft Specification Table
Part Number 08-422-8
Engine -9999 Chevrolet
305ci-350ci
8cyl.
Grind Number CS XR270HR-10
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.495 0.502
Duration At 0.006 Tappet Lift 270 276
Valve Timing At 0.006
Open Close
Intake 29 61
Exhaust 72 24
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 218 224
Lobe Lift 0.33 0.335
Lobe Separation 110
Recommended Valve Springs 986-16
6. 3.23 posi diff
305ci-350ci
8cyl.
Description
Intake Exhaust
Open Close
Intake 29 61
Exhaust 72 24
Intake Exhaust
Lobe Separation 110
Car: SOLD!!!!!
Re: got the combination set up. now need the cam
what about this cam
howards cam
Brand:
Howards Cams
Manufacturer's Part Number:
181145-12
Part Type:
Camshafts
Product Line:
Howards Cams Hydraulic Roller Camshafts
Summit Racing Part Number:
HRS-181145-12
Cam Style:
Hydraulic roller tappet
Basic Operating RPM Range:
1,500-5,600
Intake Duration at 050 inch Lift:
219
Exhaust Duration at 050 inch Lift:
225
219 int./225 exh.
Advertised Intake Duration:
272
Advertised Exhaust Duration:
278
Advertised Duration:
272 int./278 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:
0.510 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:
0.525 in.
0.510 int./0.525 exh.
Lobe Separation (degrees):
112
Camshaft Gear Attachment:
3-bolt
Computer-Controlled Compatible:
No
Valve Springs Required:
Yes
Camshaft Manufacturers Description:
Fair idle, good all-around performance. Good vacuum. Computer compatible with chip.
howards cam
Brand:
Howards Cams
181145-12
Part Type:
Camshafts
Product Line:
HRS-181145-12
Cam Style:
1,500-5,600
219
225
219 int./225 exh.
272
278
272 int./278 exh.
0.510 in.
0.525 in.
112
3-bolt
No
Yes
Car: 1983 G20 Chevy
Transmission: 4L60
Don't know if they still have any available, but I picked up a Lunati version of the hotcam on closeout from Lunati a couple weeks back and it was under $90.00 shipped.
http://www.lunatipower.com/Product.aspx?id=2607
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
i suspect the 270HR won't peak much before 5500, even though your intake runners seem about right (small enough) for the power band. what's your CR on this? 5500 is anticipated redline/shifting or..?
build plan dont sound too bad otherwise!
added: what are you doing for tuning?
colton_carlson
Mar 8, 2019 12:21 PM
ambainb
Apr 25, 2016 09:21 PM
