1982 Trans Am Crossfire Fuel Injection
Old Jun 3, 2014 | 07:07 AM
maxxboost's Avatar
Hi,
I am new to the forum and in search of a special part, marked in red in the pictures below. It is hardly visible when the air cleaner is installed, it is wired with an orange, brown and red cable and sits below the wiper motor.
How is this part called in English?
Attached Thumbnails 1982 Trans Am Crossfire Fuel Injection-1.jpg   1982 Trans Am Crossfire Fuel Injection-2.jpg
Old Jun 3, 2014 | 09:34 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 1982 Trans Am Crossfire Fuel Injection
It is an "Oil Pressure Sender/Switch"
If you get a new one be sure that it has the three terminals. There are also ones that have a single terminal and are only for oil pressure, no switch for the fuel pump.
RBob.
Old Jun 3, 2014 | 09:49 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
Old Jun 3, 2014 | 01:25 PM
maxxboost's Avatar
Thanks a lot!
Old Jun 9, 2014 | 11:35 AM
xfire's Avatar
hi i have the same car. can you please post pics of your egr its bolted to the upper intake behind the throttle body and has some hoses running to it. when i bought my car the air pump was gone and i would like to see how the hoses are routed. Thanks
Old Jun 11, 2014 | 02:08 AM
maxxboost's Avatar
Hi I can take the pictures tomorrow if still needed. Getting a new garage, my car is at another site.
Old Jun 11, 2014 | 09:37 PM
xfire's Avatar
That would be great. Thanks
Old Jun 20, 2014 | 09:53 PM
Javier's Avatar
Car: 1983 Pontiac Trans Am
Engine: 5.0 Crossfire Injection
Transmission: 700 4R
Axle/Gears: 4.10
I will post some tomorrow if you still need them
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
86Base
Aug 13, 2015 05:06 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
