Help with LU5 TPS voltage
Subscribe
Jun 24, 2014 | 12:01 PM
Hopefully I'm posting this in the right forum - - I've been restoring a 1982 Recaro T/A (Crossfire) for the past year and had it to the point where it was running fairly well. Recently, though, based on the way the motor was idling and accelerating, I decided to check the TPS. Voltage, even with rotating the TPS up and down, was between 4-5 V, well above the .525 (+ or - .075) in the manual. Thought I would solve the problem by installing a new TPS, but the voltage is still excessive and the idle and acceleration have not improved. I'm using a standard multimeter and out of ideas at this point on why the TPS voltage is so far out of range. Thanks in advance for any help on this issue!
Reply 0
Jun 25, 2014 | 07:25 AM
Re: Help with LU5 TPS voltage
Check the ground wire on the TPS, it goes to the engine block.
RBob.
Reply 0
Jun 26, 2014 | 11:07 AM
Just curious - do you have the multimeter set correctly?
Put it on the battery or a definite 12 v source and see what you get. If it reads high, you might need to adjust the voltage range setting.
Reply 0
Jun 27, 2014 | 10:43 PM
Thanks and good question, because I've been humbled too many times working on cars! Pretty sure though the meter is set correctly because I checked it on the battery as suggested. Will try to troubleshoot over the weekend. Jim
Reply 0
Jun 28, 2014 | 11:12 PM
Are you checking the correct wire?
Reply 0
Subscribe
