leaking fuel from evap can after new fuel oump
Old Jul 8, 2014 | 04:18 PM
89fbomb's Avatar
So this my 1st go at this tread thing. So here's my problem awhile back my fuel pump decided to take a permanent rest. Did the whole replacement thing which took my the whole weekend ( 1st time doing it, don't judge). Got it done started right up, next day got it smoged (it was overdue) passed drove it back and forth no problems what so ever. Next day was gonna go get it an alignment done got within 4 blocks stalls on me just dies no warning managed to get it home. Get home to find it leaking fuel from the evap can on the front driver side. I read it could be I swapped 2 vent line went under the car swapped them but it still spilling fuel from the same place if anyone has any clue as to what I should do please let me know. I'm dreading the idea of having to lower that demon sac called a fuel tank. Thanks in advance
P.S it's an 89 camaro tbi 305 the pump was a jegs 255
Old Jul 8, 2014 | 05:59 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: leaking fuel from evap can after new fuel oump
Pull the lines at the cannister. have someone start it and while you're holding the lines, make sure no fuel is running out of either...like under a bit of pressure...could be you swapped a cannister like with the return line...you want someone in the car to be able to shut it off quickly "just in case".
That said, it's also possible the cannister just filled with fuel...overly filled tank, hot day, etc...seen it before when the purge solenoid is not working correctly.
Old Jul 16, 2014 | 06:07 PM
89fbomb's Avatar
I swapped the vent lines after I noticed the fuel leaked from the can. And notice the 2 lines were different sizes and thought to myself how did I miss that but I'll try it out this weekend been having to much stuff come up hopefullybthat fixes it
Old Oct 26, 2014 | 06:57 PM
89fbomb's Avatar
Problem with evap can fixed but engine still dies. Doesn't stumble, stall just dies I've changed fuel pump (original problem) rebuilt the tbi unit, new fuel filter, injectors spray pattern is normal don't know what else to do
Old Oct 27, 2014 | 10:09 AM
Schurkey's Avatar
Check the ignition?
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
beachrodder
Aug 25, 2015 08:05 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
