91 305 with a fuel pump under the hood
Car: 1970 K25, 1986 K5
Engine: Both 350s
Transmission: SM465
Axle/Gears: Dana 44/60 10-bolts
Me and my son just purchased a 91 RS. It has the 305 w/ a 5speed. The car drove ok. Once we got it home and really started looking I noticed a PO had installed a fuel pump under the hood (see pic). I didn't think those type pumps could pull fuel that far and maintain pressure at the TBI. I have not gotten under the car to see what is going on at the fuel tank yet. The car stumbles at higher RPMs. Any help is appreciated. Thanks,
Jim
Jim
Axle/Gears: 10 Bolt 2.73 Open
Re: 91 305 with a fuel pump under the hood
Generally I'd agree with you. They normally want those mounted as close to the tank as possible.
The only thing I can think of is the factory pump was still working, but low on pressure. Adding this as a "booster" was perhaps easier than pulling the tank.
Engine: Both 350s
Transmission: SM465
Knowing my luck he wired his new pump in and left the original unhooked and is trying to pull fuel through the in-tank pump. Looks like me and my son will be dropping the tank. Thanks,
That is the pump. Click on the thumbnaiil, then again on the photo, then again to zoom in.
Can you hear the in-tank original run when you turn the key on? Mine isn't super loud, but if it's quiet in the garage, I can hear it in the driver seat. Of course, you may have two running, so maybe have your son key it up while you listen at the back wheel?
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
Recommend removal of hood pump. Drop tank, replace pump w/tpi pump. Verify operation.
with external pumps, it's not -really- about how far from the tank it is, it's how much restriction you have on the inlet.
pumps like to push, not pull.
if it's sucking through stock plumbing, for example a dead stock pump and a filter (having the pump post-filter is extra stupid) you have problems.
if it was done properly, through a straight line with only a sock in the tank, and a filter after the pump, i wouldnt even worry about it, at least for now
Engine: Both 350s
Transmission: SM465
I will see if I can hear the in-tank pump. I verified the stock filter is installed. But, will plan to drop the tank, install a tpi pump and remove the under hood pump. Thanks for the help.
Car: check
Engine: check
Transmission: check
A stock TBI in-tank pump is a turbine pump, rather easy to pull fuel through one.
I ran a TBI set up with an inline pump under the hood, no pump in the tank (retro-fit). It worked surprisingly well. Better then I expected. Before that I ran the TBI from the mechanical carb pump without a return line.
That too worked but vapor lock was an issue. Adding a return line helped with that, then went with the inline pump.
RBob.
RBob.
Engine: Both 350s
Transmission: SM465
Me and my son replaced the in tank pump with a TPI unit and got the tank back in. I have not started it yet, I wanted to remove the wire added by the PO to make sure he did not cut anything to have the under hood fuel pump run. But all in all a straight forward job. The fexible line between the pump and hard line was gone, which probably lead to the PO installing the underhood pump. We will get gas in it this afternoon and start it up. Thanks for the help!
Engine: Both 350s
Transmission: SM465
Got some fresh gas in the car this evening and she fired right up. Idled fine, no surging or sputtering. Next on the list, change out the ignition lock cylinder and key. Then get a new steering wheel, but those are topics for other threads. Thanks again!
92camaroJoe
Aug 13, 2015 06:07 AM
