vortec cam TBI
Car: 92Camaro 89 Blazer
Engine: 3.1L Turbo
vortec cam TBI
So ive searched and searched and cant find the info im looking for. i have a 350 TBI setup from a truck which i can tune the PCM. I was wondering if id gain much in torque/grunt if i switched to a stock roller vortec camshaft setup? yes the block is set up for a roller setup. Does anyone have experience with this? Also, would i need the rocker arms down to the cam or just the pushrods, lifters, dog bones, spider, cam plate thingy? Any help would be greatly appreciated.
sidenote- this is for a Blazer. the truck forums arent near as helpful as the thirdgen family.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: vortec cam TBI
To switch to a roller cam you need what you mentioned plus a factory roller cam timing chain. I recomeend a cloyes single roller chain. This one has good quality compared to the chinese parts house junk, is 3-way adjustable and works well. You can use the TBI rocker arms.
http://www.summitracing.com/parts/CLO-9-1157/
If you do run the vortec cam, I would install it 4* retarded. If you install it straight up it will be on a 106* ICL which is 5* advanced from its 111* LSA. Advancing a tiny 191/196* @ .050 cam with a tighter LSA does not make much sense in a ~9.4:1 engine. It retains enough dynamic compression ratio to need either 93 octane or a very conservative (less power) timing advance curve.
Engine: 350 TBI build
Axle/Gears: 3.73 G80
Re: vortec cam TBI
I agree 100% with fast355, I would go with a LT-1 or LT-4 cam, that's what I am using in my 89 s10 Blazer 350 TBI build
junkcltr
Aug 2, 2019 11:12 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
