LS1 Fuel pump install
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
Hey guys,
I have done some reading on the LS1 install and I have one question that I cannot seem to find a definitive answer on. It is about the small Brass barb fitting on the top that would usually be plumbed down to the bottom of the bucket. What am I supposed to do with it if I am not using the LS1 sending unit? just route a tube back to the bottom and zip tie it in place?
Regards.
Regards.
Car: check
Engine: check
Transmission: check
Re: LS1 Fuel pump install
Block it off. The fuel from that fitting was used to power a jet pump in the bottom of the bucket. It pulled fuel into the bucket from the tank side of it.
RBob.
RBob.
Roger, Thanks RBob. After 7 years, I'm finally getting close to trying out your EBL, can't wait.
