FPR Spring
Old Dec 2, 2014 | 02:08 AM
Mr.ChevyStroker's Avatar
Car: RS Camaro
Engine: 97 L31 350:Eventually a stroker
Transmission: WC T-5
Axle/Gears: Zexel Torsen 3.73s
FPR Spring
Since I upgraded to a 97 L31 vortec engine, I was told I'd need to bump my fuel pressure regulator spring. Is this one a okay upgrade? It's like 20 psi to run it. So there's a 18 psi spring, and then a 28 psi spring, I think One is a little much, but I don't know. They're both 8 bucks so What should i go with?
http://www.summitracing.com/parts/bdd-1500318
Old Dec 2, 2014 | 02:19 AM
static80's Avatar
Car: 89 RS
Engine: 305 TBI
Re: FPR Spring
I haven't done this but found an article on modifying the stock fpr to make it adjustable
https://www.thirdgen.org/tbi-afpr
Old Dec 2, 2014 | 03:50 AM
Car: RS Camaro
Re: FPR Spring
I just breezed through it and it makes some sense. Definitely a slow patient percedure. Ill have to read it again tomorrow and maybe ill do that. Although turbocity doesnt sell tbi stuff anymore. So that is a challenge. .. :/
Old Dec 4, 2014 | 01:07 AM
Car: RS Camaro
Re: FPR Spring
How would I exactly know what my fuel pressure would be at if i did it this way? Without having to take it off every time to adjust it?
Old Dec 4, 2014 | 01:33 AM
static80's Avatar
Car: 89 RS
Engine: 305 TBI
Re: FPR Spring
You need something like this to check your fuel pressure
http://www.ebay.ca/itm/TBI-Throttle-...-/260732758647
or this
http://marine-performance-parts.com/...843505774.aspx
Old Dec 4, 2014 | 01:50 AM
Car: RS Camaro
Re: FPR Spring
After i were to purchase that, i'd only need the actual needle and gauge correct? That CFM tech one is nifty, allowing you to keep it on there running through the hardline, and keep the gauge on there. I'm gonna have to do this next paycheck.
Also. I think my fuel delivery at delivery, like when i apply throttle is well. when I turn it on, it just wants to die, like bent fuel line or not enough pressure. then after it warms up a little bit it will idle, but the idle jump from like 1200 to 500 a few times, then dies. Is that fuel pressure possibly?
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Lmancha96
Sep 25, 2015 08:11 PM
