Stock ignition timing with the Renegade?
Old Dec 22, 2014 | 06:50 PM
83 CrossfireZ28's Avatar
Car: 1983 Camaro Z28
Engine: 5.0L 305 Cross-Fire Injection
Transmission: 700-R4
Axle/Gears: 3.23 Limited Slip
Just thought I'd throw the question out there to anyone who has installed the Renegade manifold on there engine. Do you use the stock ignition timing setting of 6 degrees? I have some issues with the way mine is running and I think the problem I'm having is due to a lack of timing. Have any of you advanced the timing?
I'm interested in hearing what base timing you guys are running.
Old Dec 23, 2014 | 10:25 AM
Re: Stock ignition timing with the Renegade?
Typical small block Chevy base timing is 8 to 12 degrees, right? Why would would base timing on a CrossFire be 6 degrees?
Old Dec 23, 2014 | 06:02 PM
gheatly's Avatar
Car: 1982 Z-28
Engine: 5.7L Crossfire
Transmission: TH-350
Axle/Gears: GM Posi, 3.73
Because the timing is handled by the computer. The 6* initial is in case the HEI module goes bad and runs in fail safe mode. Otherwise, the ECM knows the engine is set with 6* of initial and it cancels that initial advice out in its timing calcs.
Old Dec 23, 2014 | 08:48 PM
82tarecaro's Avatar
Mine seems to run fine on slightly more timing. I think I am running 8 degrees advanced IIRC.
Old Dec 23, 2014 | 09:16 PM
Are you running the Renegade manifold?
I'm having problems with mine at low to mid range rpm, where it stumbles and falls on it's face and just feels down on power.
Old Dec 23, 2014 | 09:24 PM
82tarecaro's Avatar
Yes - I am running the Renegade. How is your fuel system? That problem can be related to low fuel pressure as well. Is it doing it when the engine is under load?
Old Dec 23, 2014 | 09:40 PM
Yes, it's doing it under load. My fuel pressure is about 12-13 pounds.
Maybe I should tell you what other things I've done. I ported the stock cylinder heads and did a light porting on the Renegade manifold. I also installed 1.6 rocker arms and replaced the valve springs and pushrods. I still have the stock cam.
Old Dec 23, 2014 | 09:48 PM
82tarecaro's Avatar
Are you still running the stock fuel pump? I wonder if you are maintaining that pressure under load. The stock fuel system should be sufficient for what you have, but you may want to upgrade your fuel pump if you still have a stock or a stock replacement. A TPI pump will give you the extra pressure you need.
Try bumping the timing up as well and see if it runs any better. I just kept playing around with timing and fuel pressure until I got it where I wanted it. The Crossfire system is far from perfect and I still get a little stumble every now and then but it runs a lot better then it did with the stock manifold and fuel pump.
Ghettobird52
Jul 5, 2024 11:18 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
camaro71633
Sep 1, 2015 10:24 AM
justin57
Aug 20, 2015 07:05 PM
Thirim
Aug 9, 2015 06:19 PM
