ECM not recieving signal from Distributor indicating the engine is turning. No fuel.
Old Jun 5, 2015 | 02:04 AM
STEEL's Avatar
Car: 1991 Camaro RS
Engine: LO3
Engine ran just fine when taken out two months ago.
Just put the engine back in. Has spark, CEL comes on when the key is on and engine is off. Injectors have 12 volts, and if you ground them manually they spray a lot of fuel. Brand new ignition control module.
If you put 12v to the Purple/white wire coming off the distributor it will cause the injectors to spray, but plugged into the distributor spark happens and the injectors do nothing.
There is a tach lead from the coil itself. I attempted to run a paperclip from the tach lead to the Purple/White. Truck started but wouldnt idle.
Im at my witts end. How can the new ignition module not be sending the reference signal either? Where else could the issue even be?
Old Jun 5, 2015 | 07:00 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: ECM not recieving signal from Distributor indicating the engine is turning. No f
Check and clean bottom surface of the ICM. Make sure that distributor mounting flange is also clean. Do not use too much thermal compound (white or clear looking compound) when installing ICM into dizzy. It's common to find 'new' ICM defective. A good used GM unit should do job in a stock application. Lastly, check all grounds, distributor clamp.
//RF
89GTAOz
May 16, 2020 09:31 AM
Caspar
Jun 19, 2016 11:19 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
djmarch
Aug 10, 2015 08:42 AM
marcusaw
Aug 10, 2015 08:13 AM
