Are all Crossfire Injection 3rd gen Fuel Lines the same?
Car: 83 Z28, 84 Z28
Engine: 5.0 Cross Fire, 5.0 H.O.
Transmission: 4 Speed Auto, 5 Speed Manual
I took a shot in the dark ordering a TBI To Filter Line for an 82 camaro from classic tube, A)out of desperation, and B) under the assumption that crossfire was the only TBI offered in 82... so why wouldn't it fit. Anyone have any insight as to whether or not this line will fit an 83?
Also if it doesn't fit, would I be able to cut out the middle and use a rubber fuel line and just utilize the metal connectors? or is there too much pressure in this system?
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Are all Crossfire Injection 3rd gen Fuel Lines the same?
the base 4 cyl engine in '82 had TBI...-a single 1 11/16" instead of the dual 1 13/16"of the v8.Fuel pressure on a crossfire maxes out at ~13 PSI,so you will need hose suitable for at least that much pressure.I used -6 braided line for my crossfire.
Car: 83 Z28, 84 Z28
Thanks for the info on the substitute hose, the 82 fule line i ordered is for a 305 tbi so im assuming that means an 82 crossfire and hoping that means it will fit an 83... Either way ill post an update in 2 weeks when i get it. Please keep the advice coming in the mean time
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
