What PROM do I need?
Old Jun 30, 2015 | 09:05 PM
BLK87Z's Avatar
Hey guys, just started a 355 swap into a 305 B4U Caprice LTZ. It's a nice 1992 model with G81 factory limited slip, GU5 3.23 gears, V08 heavy duty cooling, FE3 Sport Suspension and B4U Sport Performance Package.
The engine is a 77 model 4 bolt 010 block, bored .030 over with flat top pistons, vortec heads, a Comp Cams XE256, and the intake is an Edelbrock Performer RPM (not the air gap). Long tube summit B body headers, adding 3 wire oxygen sensor, and Im deleting the EGR as we are not required to have it and my intake is not provisioned for it. I'll be using a TBI unit from a 93 9C1 350 Caprice. Id also like to have it not set a light for the transmission as I run a stand alone 700R4 Raptor that has a 4th gear lockup controlled without the pcm.
I don't want to do EBL, id just like to have something I can plug in and go, doesn't have to be perfect, just close. Will the 9C1 prom get me close? Is there a way to trick the egr to think its still working? Will the TCC being unhooked get me a CEL?
Old Jul 9, 2015 | 05:02 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: What PROM do I need?
The 355 will probably be capable of producing 100hp more that the LO3 does, tweaking the just the chip will not get the job done.
Originally Posted by BLK87Z
...a stand alone 700R4 Raptor that has a 4th gear lockup...
I also bought that same piece of junk 700R4 Raptor from PATC, it shifted harsh and it blew the fuse every time it shifted to 4th gear
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
dusterbd
Sep 29, 2015 08:40 AM
BLK87Z
Sep 18, 2015 11:29 PM
Winchester1094
Sep 15, 2015 09:48 AM
