Need help getting my 92 started
Old Jul 12, 2015 | 03:15 PM
1992Camaro5.7's Avatar
Car: 1992 Camaro RS
Engine: 350 TBI
Currently trying to get my 1992 RS (still have the 305) started, have spark and she's turning over but she won't start.
Does anyone have some basic trouble shooting that they would recommend? I assume she isn't getting fuel. Is there any form of fuel cut-off that might have been triggered when I had her towed?
Any help would be appreciated.
Old Jul 12, 2015 | 04:03 PM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
Re: Need help getting my 92 started
turn the key on and get down on ur belly by the tank and see if the fuel pump is turning on... if u cannot hear it ... give the tank a tap the flat side on a hammer
Old Jul 12, 2015 | 04:31 PM
Car: 1992 Camaro RS
Engine: 350 TBI
Will give that a shot thanks
Old Jul 12, 2015 | 05:14 PM
Schurkey's Avatar
The fuel pump is supposed to run for TWO SECONDS when the key is first turned on.
Therefore you cannot turn the key on, run back to the tank, and think you're going to hear the fuel pump.
1. Do the injectors spray fuel when the engine is cranking?
2. If no injector spray, will the engine start if you spray aerosol carb cleaner into the throttle body? Even a splash of gasoline might work.
3. Buy or borrow a fuel pressure gauge and adapter, and tell us how much fuel pressure you have?
Old Jul 12, 2015 | 05:52 PM
Engine: V8 305
yes you will need a partner to turn the key for you.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
