help me find the computer please
Old Jul 26, 2015 | 06:32 PM
84tr's Avatar
Hi, acquired an 84 Firebird, 305 last year and the engine has died. Going down the route of swapping a 350. Reading through the forums I came across information that some Canadian cars did not come with a computer. To be sure I took apart the passenger side compartment area and looked but did not find computer. I have taken a few pics of the engine and passenger side area. Where do you guys think this computer or ecm is?
Old Jul 26, 2015 | 06:54 PM
Queball's Avatar
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
Re: help me find the computer please
https://www.thirdgen.org/forums/elec...-computer.html
might help
Old Jul 26, 2015 | 06:59 PM
84tr's Avatar
Thanks I'll have a read
Old Jul 27, 2015 | 02:28 AM
84tr's Avatar
Originally Posted by Queball
I read it and according to the electronics forum, it should be there...I am unable to find it in the passenger foot area, any ideas?
Old Jul 27, 2015 | 04:38 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
The computer/ECU is relatively large, on a large bracket, with many wires going to it, but tucked up underneath the pass side dash. You shouldn't have to do anything other than remove the bottom cover if it even had one. You may have to lay upside down to look up there. There would also be a harness going from there to the inner pass fender and then up and over behind the strut tower in the engine compartment.
Your carburetor doesn't look like it's computer controlled and I'm not sure what if anything was there before the computer controlled carb.
Pic of what computer looks like (w/ bracket and cruise control piggy back)
http://www.eecis.udel.edu/~davis/z28...70fullside.jpg
What a computer controlled carb looks like (note blue right angled connector on top):
http://assets.hemmings.com/story_ima...071-1000-0.jpg
http://www.hotrodders.com/gallery/data/500/Q_Jet.jpg
Old Jul 27, 2015 | 11:33 PM
morgsie's Avatar
That looks like a non-CCC Q-jet to me. Note the lack of a mixture solenoid. I also don't see a map sensor on the firewall. I think it's a redundant at this stage, but check under your distributor cap, if there's weights and springs it's definitely NOT computer controlled. Not uncommon for Canadian cars to have non-CCC Q-jets and mechanical distributors right up until the late 80s.
Old Jul 28, 2015 | 12:17 AM
84tr's Avatar
You guys are correct, I have a a non computer controlled carb and no computer, thank you morgsie
eightsixseven
Dec 16, 2024 01:50 PM
GTAman
Sep 21, 2015 09:57 AM
ChaseDale3and8
Sep 1, 2015 01:49 PM
E Rod
Aug 28, 2015 05:17 AM
Bryan F
Aug 18, 2015 02:28 PM
