Missing when cold HELP!
Old Aug 1, 2015 | 09:14 AM
Camaro199677's Avatar
Car: 1985 Camaro Z28
Engine: Work In Progress
Transmission: 700R4/2200 stall/Shift Kit
Axle/Gears: 7.5 Richmond 3.73/Gov Loc Posi
So I have a 1989 Camaro RS TBI and needless to say it runs like crap when it's cold. And I don't mean the temperature outside but when it first starts up. It misses, tries to die, sometimes it does die! and sputters really bad. It's really annoying and I NEED to fix it. I replaced the EGR valve and the IAC valve. Checked the TPS voltage and it was 0.62v and at full throttle its around 4.6v. Also replaced IAT sensor.
The previous owner rigged it to where when the AC is on max it turns the fan on and visa versa. I don't know if this would have anything to do with it.
Let me know what you guys think thanks
Old Aug 2, 2015 | 07:27 PM
ex-x-fire's Avatar
Re: Missing when cold HELP!
Check your fuel pressure, should be 9-12 psi.
Do a coolant temp sensor test, you'll need an ohm meter. When the car sitting overnite the cts should read close to the outside temp. Measure it when hot too.
Attached Thumbnails Missing when cold HELP!-chart.jpg   Missing when cold HELP!-0996b43f80219afb.gif
Old Aug 2, 2015 | 07:35 PM
Queball's Avatar
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
when was the last time the Plug wires, cap n rotor , spark plugs, ICM was changed?
are the spark plug wires in the right firing order as well?
before you get to techical with the hard stuff check the easy stuff first..
92firebirdguy
Sep 1, 2016 07:53 AM
devilschariot
Feb 25, 2016 03:08 AM
92-Formula
Dec 12, 2015 10:34 PM
tyeo098
Nov 30, 2015 06:27 PM
BLK87Z
Sep 18, 2015 11:29 PM
